How is old mate hrd-hr30 at it agian, he loves good blew
http://www.skylinesaustralia.com/forums/in...60&start=60
The guy should go die
roflz, he's a pretty good bloke, and i can 100% understand why's he pissed, caus i know i would be if i was him.
I'm sure he is ok, he is just a sour, narrow minded clown who can't get over the fact a few "kids" who drove a certain hill climb road nearly every other day ran some decent times up it.
I told him if he gets the locks taken off the gates, and has the road re opened the owner of my car is willing to take it up. I guess when push comes to shove on forums, no one coughs up but me be it prize money (sd.com.com.au) or getting my old car and the new owner up to recored the same times
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
