How is old mate hrd-hr30 at it agian, he loves good blew
http://www.skylinesaustralia.com/forums/in...60&start=60
The guy should go die
roflz, he's a pretty good bloke, and i can 100% understand why's he pissed, caus i know i would be if i was him.
I'm sure he is ok, he is just a sour, narrow minded clown who can't get over the fact a few "kids" who drove a certain hill climb road nearly every other day ran some decent times up it.
I told him if he gets the locks taken off the gates, and has the road re opened the owner of my car is willing to take it up. I guess when push comes to shove on forums, no one coughs up but me be it prize money (sd.com.com.au) or getting my old car and the new owner up to recored the same times
