Depends on wether you are at the wading pool or the big pool. :)
is there a difference between preving and admiring?
We had an in depth convo at maccas on the weekend (as you do) in regard to rape. More so being caught having consensual sex with someone under 16, EI: Stat rape. My theory is, unless you blow in them.. or at all for that matter, could you argue you didn't actually have sex, and just penetrated an under age.
discuss.
discuss.
pass on this topic
Yo submarine, you got that car goin yet bro?
Nut, apparently the new Msd is NOT compatable with the microtech and it needs extra drivers to work it and so on and so on. Its getting around $1200 to fix, so im looking at other options at the moment.
And if anyone is thinking of buying a Microtech its aftersales service is SHITHOUSE.
Edited by subzeroR33
Other then being cheap, can i ask why you went the mircoleb, say over something else?
Edited by Nismo_Boy
discuss.
i want to coment but i'm a Virgin :)
