Sup Col, hey, anyone know anywhere that will give a 21yr old an 18k unsecured loan for 4-5 years with weekly repayments of ~100? :pwned:
Arent you buying a R33??? YOu can have mine for 15..that should bring the repayment down a bit!!! :pwned:
Sup Col, hey, anyone know anywhere that will give a 21yr old an 18k unsecured loan for 4-5 years with weekly repayments of ~100? :P
Rob a bank maby :ninja:
Arent you buying a R33??? YOu can have mine for 15..that should bring the repayment down a bit!!! :P
15k thats a top price :pwned:
1st mod: rip that farking muffler off and replace it with a proper one :P
:P
Im not touching that one... Its between admin and the user...
forum drama off the port bow
Ya :pwned:
Help help I'm being oppressed!
Anyway, yeah, waiting for a reply from someone about a loan, don't think they'll do anything though.
Might give the dealers finance person a email and see what they can offer me.
Edited by Hell Fire
You complain about a rattly clutch but want a screamer pipe and a loud exhaust....fecking ricer
i like to hear what the car's doing, with that farking whisper quite exhaust u cant hear anything!
and i only complained about them rattly clutches to fire u lot up :pwned:
hey col how come you aint bashed the user in the for sale thread sayinara??
News to me, you should hit the report button to direct my attention towards a thread...
which admin?
Just admin allright, I have distanced myself from this matter weeks ago I have nothing more to say about it.
Ive stayed out of it and I wish to remain out of it. That is all I have to say about this matter.
Get a hearing aid grandpa :pwned:
says the man who'se older than i :pwned:
alrite alrite i wont ask anymore sheesh
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
