well me and a few other guys have worked out some ideas and i'm gonna run a dry sump now, only 3 stage but it'll be heaps better than a wet sump setup :thumbsup:
And it will add another 3 months to the launch date of the mythical ShaneF gtr. :D
Pfft that has no purpose, f**king c notch ya car man..
*jealous of shanes dry sump*
And it will add another 3 months to the launch date of the mythical ShaneF gtr. :thumbsup:
nah, i'll be able to do it for under 1k. no need for N1 pump (~450) or sump work (500) so tis a win win situation :D
rofl, better not tell mr magazine mechanic man :angry:
:rant::D
Couldnt be f**ked liftin the wheelz in to the car. It can wait till the weekend. OH! My gtr wing is ready at the painters too. So many toys, so little time.
i've got a feeling shane's gonna be rich soon :thumbsup:
Are you tigging your own sump man? a real "car nut" will custom make his own dry sump system in his back yard :laughing-smiley-014:
With garden hose and an old electric kettle. A true Ippy modifier. :laughing-smiley-014:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
