Hmm, so whats up guys, im so so bored
fark all buddy
comin to dinner this week? or are you gonna pussy out yet again? ;)
Did you lose??
What area did you have to go to?
yeah we lost quite miserable :)
we went right into george st in the city for my stuff, and then windsor for noels stuff
fark all buddy
Ahhh I see! What did you buy? Or is it secrets?
fuel system
1 gtr pump, 2 bosch 979 pumps, 2 ltr surge tank, heaps of braided lines, 2 filters
u know i dont keep them kinda secrets lol
hahahah. more goodies, almost finished shane?
yeah more goodies, the list is getting shorter ;)
almost yes
"only" need fuel reg, dry sump pump lines & tank, exhaust fabbed up, cooler made, cooler pipes fabbed up, then it can go to my tuner for the ecu install and tune
but before i got mountain 'crusing' or track days i need suspension & brakes
Cool!
I wasnt sure, it is a bit of a trend these days
most ppl will tell if u ask
almost yes
I am almost finished...you are what is known in the industry as f**king miles away ha ha
haha eat a dick fanboy ;)
plus u've got pedro's cousin hookups, i have none :)
the cousins have been handy
If my brother the Toyota master technician would actually spin a spanner for me I would be set,,,asshole ha ha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
