If hes farkin miles away Andy I am farkin light yearts away. ;)
yes but u see i'll be of the age where i can still enjoy mine, whoever ur son willl be the only one in ur family :)
the cousins have been handy
If my brother the Toyota master technician would actually spin a spanner for me I would be set,,,asshole ha ha
maybe its time for that 2j? :P
P.S theres one for sale in the forums, 6k with decent bolt ons :)
Oh hell yeah, When i get depressed i just go out in the garage and look at my goodys. VROOM! VROOM! :laughing-smiley-014:
What goodies are there???
I spring you advice then you keep me out of the loop
Well I never
Start with this
Genuine Greddy RB25DET intake plenum, imported from nengun by me. Uses standard injectors, or I have a cool injector conversion system that will allow fitment of 14mm injectors. $900 ono - SOLD FineLine pending payment
Nissan genuine RB25DET metal intake manifold gasket $80.00- SOLD FineLine pending payment
RB25DET High Flow 14mm injector fuel rail conversion for RB25DET. Blue anodised billet aluminium with all -6 speedflow fittings. $150- SOLD FineLine pending payment
Aeromotive A1000 -6 Injected Bypass Fuel Pressure, matches the rail with 2 returns from the rail with a central fuel feed to the rail. $220 ono- SOLD FineLine pending payment
Set of 6 new in boxes 650cc low impedance 14mm delphi injectors. 1.1ms stable $450 ono.- SOLD FineLine pending payment
Tomei oil restrictor kit $5- SOLD FineLine pending pa
ohhhhh!, thought you'd never ask. :laughing-smiley-014: how long have you got?
3.532323 minutes
u should see noels new head andy, they've taken to it with a 'c**t scraper' as dan said ;)
Sweet, we will have to compare heads noel :)
What other things are in the engine?
Start with this
I see, Short runners FTL Noel ;) then again you love drag racing so I guess it works! sounds good mate...now sort out the turbo!
3.532323 minutes
Sweet, we will have to compare heads noel ;)
hmmm. bottom end....crank and rods, peened, cryo frozen carck tested, blueprinted and balanced.
OS giken forged slugs oil squirter notched.
farkin awesome port job on the head including chamber modification and cc matched
On order. Hot cams, adjusto gears. stronger valve springs. Himount manifold, 30/40 garret.
On the shelf as well. q45 afm, q45 throttle body
waiting to be pulled out of car. pro comp power fc with launch control and laptop compatible.
Nice!
Sound like a twin for mine ;) noice
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
