nah 1.5 JZ
quick pass that one nearly as quick as shane's hybrid. pppffffffttt
there is no flow bench testing proving the 1j head is better then the 2jz head.
Why build a 1.5j for the hell of it? You'd only do it if:
a) your 1jz blew up
b) you had a high end 1jz head already built with a shagged bottom
I've done the cost's, starting from nothing its cheaper to just use a 2jz.
Edited by Nismo_Boy
josh i hope these cars ur bringing to the dyno day have got some decent power :)
One is a stock R32 with open pipes, the other is a "close too" 2.7lt, built head, motec, GT-RS turbos ect. We'll see, I wana tinker with timming and fuel to pop 400rwkw, my mate is being a pussy and just wants to roll on 18psi and pump gas. I say ban him!
mmm noise & flames, hell yeah thats some half decent hp :)
Only thing holding it back is bigger injectors.. :D
Nah should be good, I reckon it'll do 320 - 350rwkw on the day. Would be nice to bump the boost more and have a play to make a magic 400.. but it's not to be maybe i'll keep talking about it and convince him :)
a) your 1jz blew up
People build em for the response as well, not just for outright power.
if its power then 2 jz all the way....stuff opening it either. :)
lol what's it with people and under sizing their injectors? :)
soo ur saying the 2.5ltr 1j head would be more responsive than the 3ltr 2j? hows that work? lol :)
its like putting a rb20 head on an rb25....it flows less HP, as in the inlets etc are smalled....but from that it prevides better response...its like putting a smaller turbo on your car....but more expensive....there are a few other details that it changes too
come on shane..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
