all good, we should see them next week at that rate.
Give me a rough price on a flash arsed pulley kit too.
Sorry mate. I'm not allowed to. Col says that forum traders complain if I put a dollar sign next to anything I write.
$It $makes $it $hard $to $help $SAUers
Bah i got one of our unit people who is a mechanic to give me a hand with them cams, everything going well, and then bang, fkn broke a stud of I6 capstud, didnt even move a bit broke straight away, You would have a spare bearing stud would ya dan? i need one or know where i can get one, IE: repco?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
