i got a headache from ur avatar.. i knw a few chinese ppl that would throw a fit if they stared at ur avatar anna
Auzumanga Daioh is awesome ! Watched the series from start to finish as it was released as fansubs a few years back.
it must suck not beaing able to launch a gtst over 3.5k :)
sif launch at 3.5, learn to slip the clutch and get some decent tyres = more RPM all day long...if drag racing is what you were refering to?
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
