Hey guys i changed my fuel filter, now my car has a strong fuel smell when you drive it. I have double checked for leaks, but cant see any.
What else could it be any suggestions.
When you changed the filter I assume you would have undone the filler cap? Did you remember to do it back up. Also make sure you wash everything (filter side) down with water. This should eliminate any excess fuel laying on panels.
Other places fuel smell can come from is if the cap isn't sealing, purge canister solenoid staying open, leaking injector, fuel lines split coming out of tank under vehicle.
Is there a problem if it doesnt seal???
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
