this morning i was down the goldy with noel picking up his car bits, and this arvo i was sleepin, u actually woke me up when u called :thumbsup:
Geez, I don't even get a mention?
You're walkin to Noels for sure.
Hey Noel....you want me to bring over my BBQ? I ported it a couple months back. Flame grill FTW!!!
y, it wasnt my stuff i was sand blasting and cleaning :laugh:
hahaha....oh and rb25 FTW!!
and ys that? :blink:
Hey every1 i new on here
so n e 1 wna make frnds wit me :P
:rolleyes::wub::bunny:
picsofunakedorban
:P jokes jokes
welcome to this here sau, also check out www.sauqld.com :yes:
yo..
please educate my friend.. im trying to convince him/her that a 1jz engine is a far better choice than a RB25 neo/RB26DETT..
for say a 180/silvia or a project car..
stock for stock or modified.. im done trying to convince him...
yo..
I was almost convinced this was the case too Marki but since i have started sniffing around motor sport circles I have heard of plenty of the 1 and 2j donks that have shit themselves. Apparently another phurphy is the story about the forged bottom end. According to one 2j owner I spoke to its nearly all bs. Forged pistons yes but thats about it. and lets face it, pistons dont make a bottom end.
Given the amount of parts and info on the rb I wouldnt hesitate to mod one again and if this one doesnt go the distance (which I am sure it will) I will find out why not and rectify it.
yep.
but u tend to see that the general JZ engine has far supirior oil dispurtion and coolant circulation.. make that bit more power standard block..thats standard to standard.
but i knw what ur talking about with just istons being forgies...
with the SR20.. u cna have a full forged engine but in the end u still got a weak alloy block and they dnt see more than 700ponies :rolleyes:
yep.
It's hard to convince him because it's not just about 'the engine'. Reliability is important of course but you aren't taking into acount ease of installation, availability of parts etc. And don't just write of RB's like that either. Yeah sure the JZ is a well designed engine but 90% of RB engine failures are tune related. Too many tuners who do a half arsed job. It'll bring the strongest engine to it's knees.
At the end of the day, like Dan said, it's not the debate of which engine is strongest in stock form, it's pretty well documented that the JZ is probably trumps in that department. But the effort involved is rediculous when looking at the comparison of swapping either engine. The conversion is no longer unique, its been done a few times before and for the extra cost involved you could have a tougher RB.
ok
im diagnosing why im getting nothing much from the RB20..
its got a Z32 AFM with standard ecu..?
does that work.. from my understanding the Z32 has a different voltage correct..?
with it cranking over im not getting the injectors to open and close (electronically)?? using a test light and checked i off Inj #1 while cranking. i have fuel flow, ignition (diagnose by playing with the ignitor) enough to splutter but not keep on going..
cas seems good. so im shooting for fuel..???
anyone..
ok
anyone..
The other thing you could try is to remove the return line from the reg and turn on the ignition. If there is not enough pressure to bypass the reg, then you will never start it.
Then check spark. I can test your coil packs, PTU and injectors with an ignition tester I have but you should make sure you are getting power to everything first. Chuck a noid light on the injectors and see if they pulse. The Z32 AFM won't work on the standard ECU as it has a different resolution, but I'm not 100% on whether it will stop it from running completely. If you get stuck......I'll happily buy the car from you for $1
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
