Whats the go with the Tuesday night dinners, do they still have them.
on sauqld...
yeah just every time you rev past 5000 rpm for more than a second all your rocker arms will snap off...sic :P
haha.. hmm $100 for tomei RAS kit.. PROBLEM SOLVED>.. now lets tackle the RB pumping oil into head problem.. yes part is $22 from tomei as well.. but couple hundred to get the head off ahahaa... :thumbsup:
ps ive had the SR on rev limiter for a good while nothing breaks.. :(
lol @ rocker arms
sr = wannabe v8 :(
pfft... ur taunts dont hurt me.. u like my 180 haha.. u saw my deep fried tyres... haha
and the new ZO6 still uses a 16v pushrod V8...
whats ur point..
anyway its raining whores...
uknw what that means watch out for billy bob and joe drifting ther fully sick commos around our roundabouts...
i just put a O2 sensor on the 180sx... haha suprise suprise alot smoother now and easier to hold certain throttle applications... :thumbsup: uknw what im talking about... anyway for $65 from nisswreck was well worth it... now what i dnt understand is why the hell it didnt have one on when i got the car..
done is done..
arc up...???
havent heard that one..
yes shane i secretly slash my wrist over the matter..
WHY WONT YOU LOVE ME....
on a lighter note shane u think i should buy a NEW PFC for 930 del with 2 weeks to wait..?
arc, u know fire up? surely ur rock isnt THAT big :thumbsup:
if im being too mean just tell me to stop...nah fark it its fun farking around lol
yeah do it dude, dont think u could get em from nywhere else for cheaper with 2 weeks lead time
i just put a O2 sensor on the 180sx... haha suprise suprise alot smoother now and easier to hold certain throttle applications... :P uknw what im talking about... anyway for $65 from nisswreck was well worth it... now what i dnt understand is why the hell it didnt have one on when i got the car..
done is done..
see now if u were an aussie, u would be one of them commo drivers, u being an asian bogan and all :(
asian commo's = 180's :(
WHAT cant you make it tonight Dingo.
I thought you live there.
Dude I started at 4.00 am this morning and not long dragged my very tired old arse through the door. If I can muster the strength I will have a quick shower and pop out for a bo peep sub. :/
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
