cant fit the tank in the boot without cutting the boot floor. The tank is 22" tall (3gal) and theres only a max of 20.5" from the base of the wheel well. However the std fuel tank runs right up underneath where the wheel well is, so theres no simple cut and shut way to do it :P
ill be round soon with the 9 inch, i love cutting shit up. You should have seen my mates drop top datto ute after i got to it with a angle grinder.
haha yeh i love my 9 inch too, gets alot of use at my place lol
the thing is, y need to run a fuel cell to fit the dry sump tank in the boot in a 32. 33 boots are deep enough u can put the tank anywhere
your gtr is neva gonna be finished
wanna put ur money where ur mouth is?
im sticking to my guns that it'll be ready early december :P
awesome if you get it done in time
but why rush it now its not like you want to cut any corners on the final stages.
Who are you going to be using for tuning??
heh, im not cutting corners, i've budgeted it out and it's come up as early december being the completion date
that's a tough one. Prolly mark from godzilla, seeing as he tune's his and theo's cars, and im going drag racing, so it seems the logical one. Also i need advice on suspension setup and diff's, and he'd know.
quick around circuits. how many drag car's have they setup?
personally, i didnt like the reception i got when i asked them what they knew about a crank trigger disk setup with the autronic.
my ultimate goal with this car is a 9, but that's not gonna happen for a year or 2 i reckon, main issue being the box
doesnt giant do a low 10 in circut setup, im sure they would know a fairbit about setting a car up to quick at the drags.
yeh they've run a 10.2, but i wouldnt get the support at a test session with cnj as i could with godzilla.
dunno, theres still a few months before it comes time to pick, so we'll see
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
