i haven't tried it.. dave says no...... as his stock radiator cooled better than a just crap one. Also the top bit where the cap goes on is only pressed in rather than welded in, creating another weak point.
the pwr ones are 740, and i can't justify 740 on a radiator, especially when I've got so much other shit to fix asap.
so.. I'm thinking ... just jap, get the top bit welded and away i go.. that'll be $430... as you know what? I'm not running a 400kw gtr like dave.. and I'm sure the gtr radiators have much much better cooling qualities than the s13 ones lol.
Import Auto Parts does full alloy ones for 399 i think atm.
Then fit a stock GTR one...
thanks, It's worth a look
remind me to never get advice from YOU
lol
kidding.. want a hug?
(I'm not really kidding)
Good Morning sau :D
morning fag
so are u using the S13 one..? the S14/S15 is an upgrade for SR S13 ones..
what engine is in the S13/180sx RB26.?
nah he's advertised at 450 then i'd have to weld
jj is 400 plus welding
he seems ok with his prices, I need heaps of crap so he might be able to do me a deal if he's a small company.
morning fag
yeah but you know the saying... do it once and do it properly.. plus an s14/s15 is proving hard to find!
the s14s are better than the s15 ones.. but each are only a marginal upgrade I hear.
it's an s14 engine in the 180 (hence why I lol'd at the comment of fitting a gtr radiator (not that i should lol considering i didn't tell anyone haha)
id buy the PWR one, along with a SPAL thermo and you will never have to worry about overheating your car again.
oh and hi to noel and shane as well
i should just do it hey
I should stop being a tightass.
myeah dont spent that much if you dont have too
my brother has one of these 399 all alloy rads and his stays at 80C when he is sliding, and i believe it still fine, and he is in NT atm. depends what you think is over kill really.
so his is a drift car?
another thing is.. mine is circuit.. so it's lap after lap after lap after lap.... you get the idea.
fark I just need a good mechanic to advise me on this one... someone who does what i do to the car, and does it week after week after week.
ahh i got ya..
might i also ask why u put the VCT S14 engine in the 180sx..? just curious
if u want quality scourer around ns.com or yahoo japan for a ARC or HKS tripple core or something.. but im sure a cooling pro 40mm radiator would be fine
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
