Hey marki one question... does she put out?
ill let u knw tuesday night.. frankly i dnt care if it leads anywher or not shes just a work mate that sort of likes me..
i dont want to pull, i dont even want to touch her, or i will get my ass thrown in jail brovah, though she can give me a bj while i am asleep if she wants.
lol INITIAL D FTW!!!
bahahahaha
haha as if get one while sleeping. thats lame.. shes 17.. all good bro.
Damn straight, i've always wanted an impact blue
yeah get the gold wheels
shit eh, i didnt realise they were letting 12yr olds get breast implants :sorcerer:
P.S all jokes aside, she looks like a gooden mark, nice one :happy:
it doesnt matter. marki believes in no sex before marriage, remember?
sucks to be him :(
lol.. ur just jealous shane.. as if i do..
anyway.. i think im gonna post up pics of ex.. im bored.
oh damn... that is whack
very...very...very..
yeah she a noice looker, dont like the stuck up kind.
i was mearly stating the point that it would be illegal for to do anything unless i didnt know it was happening....
i broke up with her cause she kissed some dude at a party when she was drunk.. josh knws the story
that's it? you broke up with her because she kissed some other guy?
haha as if u dnt want to knw whats happening..
LAST ONE
dude im a nice guy it had to be a genuine reason.. i just stopped sein her and she eventually drifted away..
lol who wants her digits..? shes a whore though
she's a whore eh, well she cant be too loose if she's 17...josh, rohan, tag team? :sorcerer:
fkn oprah is dull today. it's all about men doing 'bad' things like playing golf and not cleaning the dishes. I gave up trying to get andy to clean his own mess up, it's NOT gonna happen! :happy:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
