oh yeha.....touche....stupid shane and him having to go home....bastard.
below me
this dude is selling surge tank setup for $300 excluding the pump
I already have a tank lines and 044 how much would it cost to do the fittlings like the one pictured or would i be better off buying the surge and lines of this guy and sell my current lines and tank? Im guessing I could get $150ish for what I already have.
who does speedflow lines and fittings at a decent price?
so what is it u want to use from that setup he's selling? by the sounds of it u already have the stuff u need...
dont buy speedflow or the like (i use Earl's) in aus, as its all waaaaay too expensive. i have bought all my gear from the states (summitracing.com) however i may have found a supplier up my way who can beat the us prices...
i hope ur pockets are deep if u wanna play with braide >_<
shanef will know....where is the bish when you need him.
here now :D
im waiting for him to come and answer it for me :) any other ideas welcome!!!
also shane what are the possibilities / complications of running an aftermarket rb26 fuel rail and injector on my 25 I dont want to have to forkout for injectors again once it is 26 time. PFC running it.
problems i can see are
1) fuel rail bolt locations (rb25 side feed, rb26 top feed, rails have differing bolt locations on the plenums)
2) Injector driver in ecu/resister pack. (rb25 high impedence, rb26 low impedence, hence the resister pack on rb26's)
3) o-ring on 'bottom' of injector. the one that seats in the plenum. i've got a feeling theres some difference there too
Afternoon weirdos. I'm going to check out a car this afternoon... man am I pissing myself with excitement!!1
is said car going to sound like this?... ASS ASS ASS ASS ASS
:spank:
annananananananananananananananananananananannananananananan
hi
gl with the car!
fark you then miss ignorant :D
ok so could you do the lines in the picture for less than $200 bucks new? appprox? im guesing not even close aye
those lines and fittings look hawt and will ad 11kwatw
depends where they go to under the car...
PICSORBAN BISH
I haven't been to see it yet so these two are just from what he's given me and they're only little...
hi
gl with the car!
lizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizz
izzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzl
zzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzli
zlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzliz
hi :D
dan, u have a 33 right? them lines in that pic are to suit a 32, so the length's wont be right for ur car (u need them longer) plus a few of the fittings would have to be changed
fark you then miss ignorant >_<
f**k off.
hi :D
hey darlin, how are you?
I'm really good :D I started my beauty stuff so i'm on my way to finally having my own little career. I've already had a few randoms volunteer for waxing :sorcerer:
How's you? How's your car going I haven't heard about it in ages.
he said it includes everything you need to install im guessing this all just links up to the stocko lines under the car.
from what i can tell it will be everything bar the nos setup in the photo
hahaha good work!!!
I'm ok! But of a shitty mood today. Actually... a feral mood! My head is spinning, my shoulders ache, I'm waiting on results from a medical test before the place I wanna work at will issue me with an offer. My car is a little fooked.... that sums it up!
I saw pics of the car you're looking at! I'm excited!
its ok, i dont want to be associated with a pair of silvia owning females anyway >_<
Sweet as. I usually don't like to hang with mummies boys who collect garden ornaments for fun either :D
hahaha good work!!!
oh shit hey... *anna yells penis at liz* hahahah see I knew that'd cheer you up :spank:
I hope your test results come back with something good, are you looking at moving on from your job?
Yeh the car is a little dinged up and the engine is buggered but it's all good. That's what I was after haha
shit didnt even think of that!
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
