dad lives over here 3 weeks of every month, and he thought it would e good for me to come over for 2 weeks and stay in his apartment for something to do
so here i am :D
yo shane hypotheticly speaking,
if you had an R32 GTST that had an R33rb26 rwd conversion done its matched up to a 25 box and hardwired DLink ecu
Now take a basicly stock R33 GTST and swap the two engines between the cars loom and all - so the 32 had the 25 from the 33 and the 33 had the 26 from the 32
what are the problems/obsticles to overcome in doing this?
reason being my friend is looking at selling his freshly built car and if i can get the cash together he is considering the posibility of an engine swap
(he has decided to wear a skirt and buy a house)
you can ask me i am doing a conversion atm.....
yeah shane would blab on about r33's and rb26's...and 32's and curse each one....maybe.
but yeah as i said above....if you change everything, then just placement of items and radiator etc, and tailshaft, gearbox mount are the only bits i can think of, but then shane may think of something else.....oh you may need to make room for the different style plenum off the 26, fuel lines.....fuel pump, dump pipes...should change straight off the other car.
space wise should be fine as its a big single conversion
at the moment all i can think of is radiator and dump but they should be easy
how do the engine mounts go?
engine mounts are the same...as all the block castings are the same...as with the rb30.
but probably drive shaft...gearbox mount maybe....radiator.....space to do it...every thing else should match up...
what do you mean by driveshaft?
and the gearbox should be fine cause the 32 has a rb25box in it that th 26 is matched up with the clutch has been changed from pull to push or whatever it is
ahh touche.....if they have the same box in them it wont be a prob...but if the 26 had a 26 box, then the length of the shaft might have changed....i think you need to get a different yoke ...i will find out soon.
only problem i can see is in the loom/hard wired ecu form the rb26 car.
you have 2 options:
a) get someone who knows what they are doing and have wired in a link beofre to un-wire the ecu and transfer it into the other car
or
b) swap looms with the engines
option b would be heaps easier in my opinion, as you could do that urself pretty much, and u know its going to work (well ull have more of a chance of it working :P)
everything else will just swap straight over and bolt up :D
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • To what gain?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
