dan has just recommended for me to buy a HKS Gearbox.
Discuss.
buy my 20 box...there is nothing wrong with it,....it will last oh what 1 second with your 2billion HP.
oooo looks like i may be purchasing from greenline real soon...cam gears here i come....cam shafts later....
any have an unf**ked sump for an rb engine i can have..??
shane f**ked this one..
I had the option to buy two HKS 6 speed sq's. one had a clutch, both for GTR, i knew I should have, could have sold to your ass for profit :glare:
YOU HAD f**kEN WHAT????!!!!!!!!!???????? :ninja:
out of interest sake, what were the asking price?
a new os giken seq retails for 17.5k :D
yep, and i f**ked it good too :glare:
:D
the one without the clutch i keep thinking was under $10k. The other one was $10k - $12k.
oh dear me, u should have bought it!
i'm thinkin it could be a ppg 5 speed with billet selector forks & uprated mainshaft for me :D
sump anyone
or
loom anyone>????
im pretty sure noel has his std one laying around
rohan what are your goals with the rb25? like whats ur budget like? how big u going? (how comparable to what noel's done)
hmm ask him if you can i dont have his number.
hopefully keeping a std bottom end, if nothing is damaged.
get the head flowed a bit.
new bearings etc in engine.
cams and gears.
injectors most likely
coil packs
and about a 400hp rated turbo
i want 350hp
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
