dan has just recommended for me to buy a HKS Gearbox.
Discuss.
buy my 20 box...there is nothing wrong with it,....it will last oh what 1 second with your 2billion HP.
oooo looks like i may be purchasing from greenline real soon...cam gears here i come....cam shafts later....
any have an unf**ked sump for an rb engine i can have..??
shane f**ked this one..
I had the option to buy two HKS 6 speed sq's. one had a clutch, both for GTR, i knew I should have, could have sold to your ass for profit :glare:
YOU HAD f**kEN WHAT????!!!!!!!!!???????? :ninja:
out of interest sake, what were the asking price?
a new os giken seq retails for 17.5k :D
yep, and i f**ked it good too :glare:
:D
the one without the clutch i keep thinking was under $10k. The other one was $10k - $12k.
oh dear me, u should have bought it!
i'm thinkin it could be a ppg 5 speed with billet selector forks & uprated mainshaft for me :D
sump anyone
or
loom anyone>????
im pretty sure noel has his std one laying around
rohan what are your goals with the rb25? like whats ur budget like? how big u going? (how comparable to what noel's done)
hmm ask him if you can i dont have his number.
hopefully keeping a std bottom end, if nothing is damaged.
get the head flowed a bit.
new bearings etc in engine.
cams and gears.
injectors most likely
coil packs
and about a 400hp rated turbo
i want 350hp
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
