You need PWR like this;
He hold boost for like 10 seconds, watch right till the end of the clip :P
Nice flameage
Link doesnt work, another volvo?
ok opinions people
What price should I put on my cars?
the R33 is pretty stock, low kays with upgraded suspension, intercooler and exhaust
the R32 well it has one of every thing
I'm going to be honest here with the R33, not because it had crossed my mind to buy, but Ive looked at a few now.
My friend bought his 94 that has been repainted in GTR purple, 18's, adjustable teins, full exhaust, big FMIC, 400r body kit and a mild sound system for $8500 with roughly 115,000 - 120,00kays. To date it's only needed a turbo to manifold gasket.
I'm going to look at a forced sale R33 maybe next week, he wants $8300, but I know I can get it for $7k. Although it needs paint in a few area's.
I think your R33 to sell is a $9,000 - $10k car. I think it'll be hard pressed to get much more. I've seen a few SII's come up for low teens now..
Your R32 on the other hand.
My mate paid $18k for JapTaxis built rb26/R32 gtst. And your car has ALOT more on it in terms of a total package. I can buy my old R32 back for $23k, so anything in the middle of those two price's.
ok opinions people
R33 GTST put $14k on it...but accept 12 if offered, no lower
R32 GTST put $20K on it...but accept 16-17 if offered, no lower
I'll give you head if Andy even gets a phone call at $14k.
R33's aren't moving at all, I'm worrid if I buy this one for $7k that i wont be able to move it as its so stock
Edited by Nismo_Boy
see andy, ur gonna get reamed sooooo bad if u sell the 32 :worship:
Anything thats:
A) a "Japanese" import
and
B) Turbo
Isn't moving. Look at the top two used car sites, carpoint and car sales. Check the when listed dates at the higher priced cars and check the newer when listed dates of other just listed cars.. What do you notice? Anyone trying to sell a car now has a much lower a price
$7k wtf?
Buy it. You aren't going to buy a car to make money from it but in 2-3 years time you can bet your arse you'll still get $7k for it if you keep it in good nick.
$14k is a fair price for a virtually stock 33. I can get them in the country for 11-12. The market up here is of no importance to the market down south. And there is always going to be P platers wanting them in a few years.
$7k wtf?
Every car I have owned and bought was to make money on, which I did with the exception to my quick R32, my Lexus and my BMW. I had to stop buying imports to profit from when bought the quick R32, as the profit in it just wasn’t enough.
I’m not saying $14k isn’t a fair price, I’m just saying it wont sell, or not quick anyway. The market for R33’s is crap at the best of times; the people who do want them have a surplus amount to choose from and can realistically be picky with price and car.
Morgs on here is only asking around $12k - $13k from memory for his wife’s R33, which would have to be one of the cleanest I can find for sale.
cool I was thinking 10-11k for the 33 and 20k for the R32 so good to see my idea is about the right price
My other option is to put a stock rb25 in it and sell the other engine then sell the car, not sure what would get me more money
And as for getting reamed I have been getting reamed every day by the car so who gies a f**k lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
