no one lol.. im jumping the gun lol..
hmm gibbsy's S13 uses a 2510 and has only 283hp... he slides soo well :thumbsup:
cause his suspension is set up for it!
i must admit that my suspension is grippy on purpose...but never worked so weel before ha ha
JICs and hes got lexan windows and stripped car.. a whole different class.. :thumbsup:
im just suprised with his power figure thats all.
put 12kg rears in yours and watch it sliiiiiiiiiiiiiiiiiiiiiiiiide
serious.. chinese ftw.. lol
24kg lol.. try that at the strip..
Racing logic, d2's, HSD's, g4's, and about half a dozen more brands you see getting around (more so on American forums) are all made in China, in not most in teh same factory. They are rubbish. They under under valved for the spring rates.
EG: the valving in my coilovers with 20kg springs are the same valving used for Civic coilovers using 5kg springs. They are cheap for a reason.
hhahah
only ever use bilsteins tein or ohlins so far.. i wanna try apexi like rohan has and some hypermax.
JIC i think ill go for the 180sx next if i get sick of the teins
im after some aftermarket pads for 4spot brakes. think ill pay greenline a visit.
hhahah
My Apexi N1's pissed all over both sets of Teins I had.
price..?
ok quick question i have not paid attention really when i changed pads but do S14/15 4pot pads interchange with skyline ones.. they are 296rotors same as GTST. so it should correct.?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
