i want mrk V chaser 1jz no shit...
i recommend GKtech gregs good.
$80 got me a
RAS kit RRP $60
Boss kit RRP $30
steering spacer. RRP $30
sponsors are great :):D
woop woop u saved ...$40!!!!!!!!! :w00t::)
:w00t:
P.S lol @ rocker arms
here comes 1/4 cast, i wonder what garble he'll post today! :D
bahahahahaha 1/4 cast/....bahahahahahah
and then 1 week after that u'd be onto a 20k rebuild lol
:sorcerer:
woop woop u saved ...$40!!!!!!!!! :w00t::D
LOL AT RBs PUMPING ALL THE OIL INTO THE HEAD AND STARVING THE BOTTOM END
$40 and sent express.. some sponsors are good.. some are bad im just saying greg is good and always looks after me.
whats up with it now?
Whats wrong
The results I am getting in no way justify the effort money and heartcahe i have put into that car, and every time i get it back there is another list of crap to do to it...therefore Andy out
i wish i had sponsers like urs marki :D
least u havnt warped any valve seats...yet :)
nah seriously, is the down low that bad? head off time to see whats going on?
Trial and error mods huh.
Give up, sell, move on. it hurts money wise too much to keep at it, then what u will lose selling it
Total bullshit,
ur right shane u forget the standard bottom end can make 400kw but RBs cant. so i reckon i could build a 2JZ 6spd to 400 with 20k
getrag supra 25k
turbo 2k
fab pipe cooler + cooling 3k
ecu + tune 3k
exhaust 1k
pump + injs 1k
cams 1k
gauges + controllers 1k
fluids belts bearings 1k
clutch 1.5
=14.5k
so more like under 15k
and build parts only equate to 4k approx
how the hell did u spend 55k
i am taking into account the fact that marki had his hands on said car. hence the extravigant (sp) rebuild cost
lol ur funny. i wonder wher ull be at without dan having to hold ur hand every step of the way
what year is ur 32
Edited by markimak
no sell time so i can have a life again lol
the low down is not bad at all, however i could ave bought a highflow and put it on a stock engine and gotten a better result
you sir are exactly right im happy to spend money to see a result and have fun but at the moment i have neither!
getrag supra 25k
turbo 2k
ecu + tune 3k
exhaust 1k
pump + injs 1k
cams 1k
=13k
what year is ur 32
it is an august 93 model
not too old.. atleast its a late one.
i had same prob with the GTR bushes wearing and electrics..
with the 180sx things are cheaper and bushes are in better condition. cause its newer but i dislike the elctrics in it. have speaker drop outs and a/m gauges dropping out.
my guess its dodgy earths.
getrag supra 25k
turbo 2k
ecu + tune 3k
exhaust 1k
pump + injs 1k
cams 1k
clutch 1.5
=14.5k
*pic removed by me*
u see now why it's costing soo much?
also note, theres more to go into that list yet
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
