not too old.. atleast its a late one.
i had same prob with the GTR bushes wearing and electrics..
with the 180sx things are cheaper and bushes are in better condition. cause its newer but i dislike the elctrics in it. have speaker drop outs and a/m gauges dropping out.
my guess its dodgy earths.
i have no problems at all with that sort of thing its all been replaced anyway
i will clear it up...the car has NO problems at all, just i personally do not like the car and feel for the money I could have done better actually a lot better, if some one else bought it they could have it the way i want for probably 2k, its just i dont care enough to screw around with it again
uve got genuine gaskets and intake gaskets... wtf..? and u dnt need a genuine gtr key
thats what happens when u bust them :D
also no gtr is complete without the real key! :sorcerer:
but u have genuine gasket kit which include intake mani gasket. and new waterpump should come with a gasket too.
and u dnt need to paint covers and bay.. and nor do u need plates. just somethings u can wait out a bit
once again mark, quality of job. also why do painting later when everything is apart and stripepd now?
it doesnt say genuine gasket kit, i bought random ones from dan. when i was dummy fitting the motor i had the intake gaskets on, and they broke when i took the plenum off.
also water pumps dont use gaskets, they use gasket goop. u shoulda known that already. its oil pumps that use gaskets.
the last waterpump i fitted used gasket and silicone.. ohhh snap.. huh..?? i basted the gasket.. on ur list it says waterpump gasket but u should knw that.. u made the list.
it says
water pump & inlet manifold gasket
which means water pump (u know the big metal thigny majingy) and an intake gasket, ya farken douchbag :D
it says which means water pump (u know the big metal thigny majingy) and an intake gasket, ya farken douchbag :D
haha
why would u group water pump and inlet gasket together. why not say
a. water pump
b. inlet manifold
ppl are gonna read it and think u want a waterpump gasket.
haha
a. water pump
b. inlet manifold
caus i bought them at the same time and i know what it meant :D
plus i only had a total price, not individual prices
no they wont.
did u get to see it before i removed the link? i can pm it to you if u want a squizz...i only removed it caus theres some prices in there im not suppose to let anyone else see/know about :D
nup didnt see it... you better PM me lol
no they wont.
ur gay
they are all the same anyway.. good ol nissan for doing that.
incorrect. rb20 and 25 differentiate wiith bolt placement
i can post the imageshack link lol... but im not that much of a dick
hmm well jspec sucked today
looking for a chaser i hope..
go see iron chef imports.. he specialises in chaser
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
