paint touchup is finished on my car but i cant get it till 5.30. GRRRRRR
wtf whys that?
Screw dailys if i had one i wouldnt drive it anyway why drive a crap car when you have a good one? Just make the one you have good for all occasions!
Yeah cause it does not have the AYC, the AYC diff is a bit weak over 250awkw...i wont be taking it beyond that anyhow as the rods arent that safe beyond there either (except for the 500hp stock one i saw the other day :wave: WTF )
to do that u've gotta compromise on it in too many areas
yeh thats it, apparantly costs a fair few k to change them over too....theres always 1 that breaks the boundaries lol
id love to turn u into a euro whore
Too bloody dear
wtf whys that?
Like i said though, I dont care about playing with the big boys so ciomprimise is fine
other night put a t piece into my mates CA powered silvia got it to go up to about 10 psi but amything over it cuts the power im guessing its the factory computers "boost cut" whats the cheapest/easiest way to combat this problem?
Look what i found when searching for a new avatar
What's with the posting of pics of me, eh? I look like a little hog in a white shirt. Not cool.
Oh and with all this talk about 'my car, my car, my car'... well MY car truly shits on all your cars. Even yours noel. You know it.
snip the wire? (dont ask which one though lol)
ASS ASS ASS ASS :wave:
whens it gettin to rivers' place?
WALK WALK WALK WALK
Not sure yet, the guy I bought it off is being really good with letting me keep it at his place til I can arrange transportation.
they fail in old cars,
mine is fine....i had it regased though...i love it
WALK WALK WALK WALK
I have car trailer and 4wd let me know if you need help...i have next week off.
boost restriction. std ecus on sils have boost cut. or perhaps its fuel cut either way its gay..
get a fuel pump or FCD...
... i hear HKS make a good lil unit..
in regards to shane wanting u to cut a wire..
the wire u want to cut is orange and black.
im serious this is the boost sensor wire into the back of the ecu. it is wire 40-50 one of them on the pin out.. far out how would i knw this off the top of my head :wave:
red wire? blue wire? watch out fellas you'll blow up the building if you don't get it right! Then thousands of peoples' lives will be on your blood stained hands. How tragic.
are you going to be in/around said building?
Quit whoring and do some work.
Speaking of which, you are babysitting my 2 kids tonight. Thanks again for offering and I'll see you about 6.30 :D
/randomness
/randomness
having cake....mmm cake
supply me with beer and a hooker and i'll be there at 6:30 :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
