just found out a previous client of mine is using a logo design i was working on for her she rejected the design and told me to stop all work i was doing for her business because it was taking too long to get what she wanted
she is using the design I did with a slight change to one of the elements as far as i know i can screw her for this - she aint gonna be happy when i turn up with a bill!!
So Transport are trying to take my license back off me as they f**ked up, yeap they f**ked up. They worked out they gave me my opens inside the 3 year window haha, PLUS ontop of that they didnt add on the extra suspension times on my P's. Now they wana put me on a suspensed license or a 1 year thing, but im like you cant offer me that, Ive only lost 9 points out of 12. I have 3 left, its your problem u f**ked up, plus i'm well into me having my opens, you cant just go back in time haha
RTA suck :(
ROFLCOPTER NO MORE PORSHE MIDNIGHT RUNS
Hey shane bish, Wheres my flame pics. :D
i can make some good flaming GTST material if u want.
u wouldnt fit, shes 14....
interesting.. :worship:
bill her ass
my mate put a T3 33 GTST turbo on his 1.5L na honda.. then he just put a Vtec head on. and i just did his timing belts and stuff..
weird thing was. i put it in gear got someone on foot brakes to lock the driveline and still getting the crank to spin..???
hmm went to drift practice to watch ARE31 is doin really well and same with DRFT R33 GTST.
i wish i was out ther. time to get my car runnign again. lol
maybe if it wasnt a defected pos ud be a o k lolz
josh you know much about copyright laws?
Sorta depends on if u registered it as a copywrite as well.
For example, Slides turbo face logo is IN FACT Team Krazys club logo, as Team Krazy dont own the logo its not anyones really
as far as i was aware anything I design or take a photo of I own the copyright until I say otherwise that is usually by form of letter stating I no longer hold copyright
photo's u would need to prove u took, ur art well.. well uhave them saved in programs, so thats easy. I searched google, a bit came up. Key word it down to your industy or art work, should find something
get this: I quote her $760 to design a logo for her she basicly laughs at me and says dont worry about it she will get somewhere cheap to do it im like ok now worries go get some quotes, thinking to myself good luck!
bout 2 weeks later i get a call - Dan, I have been getting quotes and they are all like in the thousands!! One place wanted $7500! Im like yeah... did you think I was trying to rip you off or something? She goes on to say how much she loves the other work i have done for her and how she wants me to do her logo now...
So i sent here first set of concepts, she made some changes then sent changes to what she wanted, she was basicly satisfied at this point just wanted one more change and it should be good to go, any ways I get a call a week later (I had not done the change yet) She starts ranting and raving Im taking long and she wants me to stop all work I was doing for her business blah blah blah!
Next thing I find she took my artwok into someone and got a slight modification done and is using it as her new logo
This woman was my gf's boss and was supposed to be a "friend"
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
