lol hey thats the highest post count i have on any of the forums i frequent
that being said what other forums do you guys use?
I use them all, although i post the most on this one.
ns.com
pf.com
bc.com
and other car ones
And a few american car an non car forums
computer is giving me the shits: Anyone know why all of a sudden when i save a file it defaults back to the "documents" folder rather than the folder you have been working in?
why its sucks is i make a document then export a pdf for client approval and every time i make a pdf it defaults back to documents folder so you need to navigate back through the folders to the client folder your working on?
make sense?
its shit and takes up my valuable time.
u need to edit ur adobe pdf printer driver
load up adobe, open a pdf file, go to print, select the printer as "Adobe PDF", hit the properties box, under the "Adobe PDF Settings" tab theres a dropdown for "Adobe PDF Output Folder", hit the browse button to the right and selcect the location u want it to default to. hit ok and ok again and then it should be set.
thanks shane
I don't think that will work for me as I'm not really "printing" pdf's as you would in most other applications I am using the pdf export feature, and this is happening across the board not just exporting pdf's its saving / save as
if you creat a file save it in a folder then wanted to save a copy of it you would "save as" usualy it would default to save the file over the one you just created as it would be going to save in the same folder - mine is constantly defaulting back to the "documents" folder
AAAARRRGH!
otherwise, just make a copy of it in the same document, and grab the scale tool and scale it up to match,
or jus work out 35% of the original dimensions and then enter what the original dimensions would have been for the small image
BAH...what program are u usin..
Edited by RusH_
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
