i could tell you but id have to kill you...:)
rocker cover gastkets need to be changed at some point, gettin a small leak,
and the castor rod bushes need changing as they are splitting, the left one has split more than the right, but yeh...
FUN!
oh and the return fuel hose has a small crack in it, not gona cause a problem yet tho....
i love spendin money on the car knowin that its not to make it faster but to fix it so it goes normal, :)
although are there any replacement parts that i could get in those areas to replace the old dying ones with that are better than stock(performance enhancing perhaps)? fuel hoses mayb?
yay for recieving goods today,
im waiting for my power intake to arrive, im told itll be here 2mro!!
i could tell you but id have to kill you...:(
FUN!
lol yes we all know about that....crappyness.
i know exactly what you mean!
I just checked my freight tracking and it looks like my engine will be delivered today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
w00t!!! what is it??
i ordered quite a bit off Dan again as well. but this is to make it go faster. :)
its true about all these new lines coming out with some quick gadgets under the bonnets too.
hater.
all i can say is we will wait and see!
It will be kinda good to see how the rb30 goes I have got a GT3540 off an XR6 on there so the 1.06 rear
lol
myeah mine wont be doin over 7k so i guess thats about the same really.
oo that should flow really well but still have some nice response. it will be interesting to drive against you on track of course.
im probably set my limiter to 7200 as thats what robbie (RIPS) recommends the motor is built for
would be good to have a built 25 reving to something spastic like noels but Im sure my wallet has so far been considerably less damaged than noels!
Thats good rpm never the less, Id be happy with 7200rpm
And your right, the wallet amount to rev something like noels is big. The "drag" rb25 in the silvia I had did 9000rpm and to be honest, looking back it prob wasnt needed.
I had the limiter off one day and the PFC read 9800rpm i was scared :D
myeah its not needed for what i am doing.....mind if i asked how much you spend on it...PM me if you like
Who says I dont?
:D
I had the limiter off one day and the PFC read 9800rpm i was scared :P
wow....nasty...bet it was screaming like Dano's mum.
cars are the devil.
Siff mod them, they lead to heart brake.
:D:D
:D
:D:P
I was dead set scared it was going to throw something out, kinda like telling a kid not to touch the big red button you just gotta "try" an see if its worth it lol.
for shiz!!
was it still pulling??
cause i remember Bunta had his go to 10k once...he said he was like WTF!! it was still pulling like my grandma on heat. i was like dude thats nasty shit and he was like yeah it was a metaphor not being serious about my grandma..she doesnt go that strong even on viagra...and i like dude thats nasty shiz...and he was oh yeah got carried away then....
speaking of gettin carried away...
Id say it was pulling a little bit, but the turbo’s were coming out of there efficiently range, so it wasn’t worth while going that far for something so little and putting that much stress on the motor.
Really got up and moved hard 4000rpm – 8500/9000rpm
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
