I assume you mean the turbo models, IIRC the factory reckons 14.5, even at this age as long as the clutch isn't slipping or something they should still be able to easily do a high 14.
He might be thinking of NA times though by the sound of it
Stock (real stock not, boost, cooler and exhaust stock :)) will run in the mid 15s these days. Also at a test and tune reaction time doesnt count towards your final time you could sit at the line for 10 seconds and still run the same time as the clock doesnt start till you trip the beam, reaction time is for your info only if you are intent on practicing competition starts
14.7 was the quoted factory time I think Marc....and our shit fuel (makes it run on low octane map) and general age is easily making them the best part of a second worse! There is always the odd exception though
Stock (real stock not, boost, cooler and exhaust stock :) ) will run in the mid 15s these days. Also at a test and tune reaction time doesnt count towards your final time you could sit at the line for 10 seconds and still run the same time as the clock doesnt start till you trip the beam, reaction time is for your info only if you are intent on practicing competition starts
Ok. John's isnt stock after all... hahaha.
Oh yea. Makes sense. Sorry for that misleading info. So doesnt matter if I'm slow in reaction comparing to the others. :)
You've been coming out with some doozies over the last couple of days Brandon.
Question revhead? Is there a reason our thread got locked and the Sunny Coast Chat Post has not been closed? They're both very similar so their thread should probably be merged in here as well don't you think?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
