Cognac is good after a really nice meal (usually dinner). But whisky........you can drink that all day and even on the golf course.
Love it!
not all whiskey. You can never drink Bourbon. Because it's shit.
And it's a timing jitter. .. the crank trigger fixes it :P
Sorry I got all my mumbo jumbo mixed up :P
So what they said was that it is an issue that you will see more frequently as the cars are getting old.
The first thing they said was that they are using Ross crank trigger kit to resolve it - big $$$$ there
The second thing they said was that as the cars are aging dirt, oil, dust and other crap gets in the CAS and causes issues with resolution
They advised that you should either take the CAS apart and give a thorough clean or just buy a new one (which costs something like $500 new from Nissarse)
They mentioned that it is an issue that happens in 1/5 cars (makes sense if people get new CAS or get them cleaned)
They advised that Haltech Platinum Pro ECU has no issues with Nissan's optical CAS (selling pitch I think)
That is all I can recollect from my discussions with them (except for the addtional features Haltech has over Apexi PFC)
Interesting. I am almost tempted to try haltech just to save the pain of going to a crank trigger!
That's predominantly why I have gone with Haltech mate and I will put it to the test.
Don't think I can make it to drag day. Rego is due :/ gonna have to pull all finds togeather and use them feet for the next few days
The grandparents are gonna help me out which what I can't come up with thank god
Zac I can pay for your fare. But just this once.
I will eagerly await your results. See if it is possible to get a cas signal trace when it is tuned.
Me three. After speaking to M.Spry he mentioned I should by new z32 air flow meters.
Nah it's not that :P it's fuel hahah. I'm going to talk to my grandparents about making my repayment a little lower so I can have a little extra to save :D
But thanks ants :) means alot
No worries mate.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
