hmmm.
I thought would have pumped more air due to 2l?
Maybe. But a Sr with that turbo is virtually lagless where as a 26 even with stock turbos is relatively laggy. The sr turbo actually looks physically smaller than the GTR turbos.
I dont remember my 26 being that laggy.
but maybe.
I just want to muck around with the 121 and have a little fun.
might need better valve springs.
