because just straight up i want to :P no other reason than they look better and im going to be doing the gaskets soon so while off should swap. they look like a direct fit.
plus they i can fool my cluless mate that its a rb26 hahah
The plenum and throttle bodies will cost 500ish bucks or more? Then 750 to 1000 for the adaptor plate...which leaks half the time. Then you need an after market computer to run the different air intake sensors and tune wirth the itbs. The covers will probably cost another 500 ish bucks. The bonus is you will actually lose response due to the shorter runners on the plenum!!!!
Might as well buy a 26 instead. Surely there are cheaper ways to troll your mates.
thinking of buying some rb26 covers to put on the 25 and a plenum ideas thougths covers for sale...... ants?
I have an RB26 front cover which is black wrinkled coated. For the engine covers try the 4 sale section on SAU or import monster. Wrinkle finish is the way to go BTW.
Did you go for clear on yours?
yes that could probably help or most likely do the reverse and cause you endless grief
Look if someone can find me a bomb of a 33gtr.... Let's say for 15 and ill just rebuild it and get a daily
Possibly in like 5 years
Oh yeah totally forgot that you went with a whole new engine as opposed to rebuild. Did your old engine die or did you get to sell it?
nope engine was still in good nick and was able to sell it.
They are endless money pits IMO. Even after I get the car back there is still suspension to do, rear brakes, new paint job ahhhhhhh fcuk it its all too much!
Every car that you modify is an endless money pit, I have a mate who has spent more on his fourby than all of my cars combined!
