because just straight up i want to :P no other reason than they look better and im going to be doing the gaskets soon so while off should swap. they look like a direct fit.
plus they i can fool my cluless mate that its a rb26 hahah
The plenum and throttle bodies will cost 500ish bucks or more? Then 750 to 1000 for the adaptor plate...which leaks half the time. Then you need an after market computer to run the different air intake sensors and tune wirth the itbs. The covers will probably cost another 500 ish bucks. The bonus is you will actually lose response due to the shorter runners on the plenum!!!!
Might as well buy a 26 instead. Surely there are cheaper ways to troll your mates.
thinking of buying some rb26 covers to put on the 25 and a plenum ideas thougths covers for sale...... ants?
I have an RB26 front cover which is black wrinkled coated. For the engine covers try the 4 sale section on SAU or import monster. Wrinkle finish is the way to go BTW.
Did you go for clear on yours?
yes that could probably help or most likely do the reverse and cause you endless grief
Look if someone can find me a bomb of a 33gtr.... Let's say for 15 and ill just rebuild it and get a daily
Possibly in like 5 years
Oh yeah totally forgot that you went with a whole new engine as opposed to rebuild. Did your old engine die or did you get to sell it?
nope engine was still in good nick and was able to sell it.
They are endless money pits IMO. Even after I get the car back there is still suspension to do, rear brakes, new paint job ahhhhhhh fcuk it its all too much!
Every car that you modify is an endless money pit, I have a mate who has spent more on his fourby than all of my cars combined!
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
