They just had word from the national head office that they are not allowed to use any external recruiters. All recruitment must be kept in house. That sucks!
that screams the sounds of a large firm to me
So in the end it was up to me again to contact Gav :verymad: (sent him a text msg)
bottom line its not ready..........
still need to wire HKS injectors, instal new vacuum lines, waiting for fuel fittings to connect HKS fuel rail to Tomei FPR.
That really does suck from your point of view, sorry to hear it.
That was supposed to happen here too, but I am seeing more gov jobs than ever before advertised externally.
thats a fair bit of work really, he was never going to be ready today and he is a jerk for saying so
Yeah. We're seeing a bit of this type of movement lately. Once they realise that it takes a little more finesse than sending someone a message over linkedin to successfully bring someone across, they come back. :)
This is fuarked. Tell him that if it isn't done by today, you will be taking it elsewhere and expecting your money back.
the weird thing for us was that we NEVER advertised externally before, then the new government made a big deal about not allowing the use of recruiters any more...then started doing it, confusing.
I would love someone to send me a linked in message to change jobs! ha ha
Its BS central!!!!........................is what I have gathered. What I don't understand is I am not a bad customer, and he is making me feel like a one :unsure:
I am more than happy to pay what is fair.......................but is this fair????
really depressed with how it has all been managed. It is evident there are inherent cash flow problems at his end but I should not be suffering the consequences from that.
I bet you when its comes to payment he wont hold back on anything!
  • Like 1
Done.
Now I just need to remember how to log on to linkedin! :P
I only created it because I nearly changed jobs 18 months ago and they wanted me to have one to look at.
Lol! So you've only ever worked for government? Does that mean that you've never really worked? :P
Also, what's with the new profile pic?
Edited by t5iv
Nah I have worked in a few different places, but the last 9.5 years were various gov roles. Also die in a fire
Anna changed my pic, it is meant to be a gif but it does not appear to be working.
Finally caught up of this weeks whoring
So going camping again this weekend
Kinda in a bad mood. Kathryn saysshewill do one thing then gets here and is like nope don't want to do that we are doing this.... Dafuq.jpg
Lol! Thought that you may like my snide remark ;)
Where is Anna? No whoring from her? Do I have to post-dig some of her previous comments to make it feel like she's here?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
