When he clears his back log I suppose. I am guessing leading up to powercruise this weekend was a hectic time for them. I am not really in a rush any more, Anna has started working so when those funds trickle through I will go get it done.
I R Jelly
lol re backlog........guess that includes me too. Yep, 100 bucks I dont get my car this week......................again.
Just spoke with Richard, That thing is going to be mental man, Sweet they look meaty
My car? Hopefully. Richard is such a good bloke could talk to him for hours.. I was just posting in the spotted thread. they have a 34 GTR at the moment getting some HP upgrades too. to skylines both getting precision turbo upgrades.
hahaha, Will be a thrid down there in a week or so. How long are you expecting until you get it back. Are you going E85 straight off the bat with this one?
Yeah ill be going e85, in my opinion is not worth tuning on anything these days. specially if the car isnt driven as a daily. I would highly recommend giving your's a go on it Clint. It will feel like a totally different car.
In regards to time frame. I havent really set one on it and am happy for it to take as long as it take to get it right. Id like it to be ready for the downshift QR day on the 28th of this month but if it isnt im not overly fussed. Next big event i want to take it to will be powerplay or a SAU event
I'll do mine the day E85 is readdily available on the North side, that is the only thing holding me back. it is still (for now) a daily.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
