When he clears his back log I suppose. I am guessing leading up to powercruise this weekend was a hectic time for them. I am not really in a rush any more, Anna has started working so when those funds trickle through I will go get it done.
I R Jelly
lol re backlog........guess that includes me too. Yep, 100 bucks I dont get my car this week......................again.
Just spoke with Richard, That thing is going to be mental man, Sweet they look meaty
My car? Hopefully. Richard is such a good bloke could talk to him for hours.. I was just posting in the spotted thread. they have a 34 GTR at the moment getting some HP upgrades too. to skylines both getting precision turbo upgrades.
hahaha, Will be a thrid down there in a week or so. How long are you expecting until you get it back. Are you going E85 straight off the bat with this one?
Yeah ill be going e85, in my opinion is not worth tuning on anything these days. specially if the car isnt driven as a daily. I would highly recommend giving your's a go on it Clint. It will feel like a totally different car.
In regards to time frame. I havent really set one on it and am happy for it to take as long as it take to get it right. Id like it to be ready for the downshift QR day on the 28th of this month but if it isnt im not overly fussed. Next big event i want to take it to will be powerplay or a SAU event
I'll do mine the day E85 is readdily available on the North side, that is the only thing holding me back. it is still (for now) a daily.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
