Ummm, what about Steve Parish?? He's professional in my book.
I think by "professional" Mike means someone who photographs for a living, not someone who enjoys it as a hobby.
professional in that case would mean someone whos made a name for themselves in photography and does it for a living.
lol im only taking the piss, u should know that :P
and if u want an example of a professional, take me for example, im THE professional :P
$2 suckys dont get u professional names in that industry dude.
this is the 20th centry.
not the 70's where chicks did wat they wanted to get in front of the camera.
damm playboy ho's
a professional is someone who has ALL the equipment and can bring out the best in an image. if you compare them to a hobbyists, then you can see the difference. its always the slightest things that make the bigger difference. just my opinion is all
hmm mite meed to use ur head next time :P
want an invite karen? :P
true, well try it tonight then :no:
damm playboy ho's
um, john, were in the 21st century as of 7 years ago
i aint all that interested in goin out an buyin myself a 20g camera just as the base along with another 10k in lenses, etc....
im happy with my $700 camera and $300-$400 in lenses i've spent.
this is a hobby and with that amount already spent on the camera which i wont be gettin back at all, i aint goin to call myself a 'professional'.
but i do know that from what i have seen in my own photos dude... they've turned out better then what i've taken before and like i said, there are a million angles to take a photo of a car.
I had a client once, who used to shoot for national geographic and numerous surf mags, over $800k worth of gear. Now, THAT IS CRAZY STUF!
You photos don’t look too shabby in comparison to most of the newbs on here.
i'm not criticising as such, i'm just saying, that with better equipment you get better photos. they look good john (well when finished they do) its just my opinion. then again i dont think people want to be paying more because someone wanted higher quality photos.
You weren't being asked ;)
OK then A cup is not flat :no:
PS DD FTW :P
yes but i just knew u were awaiting my reply :no:
n u know they are an A cup for a fact? we could get in trouble if we keep this up :P
Guest
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
