mike... as manly as your brother may be, under the coast of skin is a girl tryin to get out.....
ur mother on the otherhand is considerin that sex change that she wanted to do to u at birth.
John that took a while for a come back...
a bit slow in recovery hey??
anyway that was so 2 pages a go get with the timess
we are now onto the emo problems and the 70's porn star side burns..
man, that took you a whole of like 5 min to come up with and thats the best you got! saying all that when you were the one being analie pounded by a 17 yr old footballer, and your tyring to call him a girl pfft. also, if i was a chick, i would be the biggest s**t ever! f*ck yeah! who wouldnt? i would just work it and get everything i wanted. plus i could play with boobs all the time, sweet!
Holy Crap :happy:
a deluded Emo!!!
hows about we play russan rulette with a 9mm :happy:
SNAP!!! i am so up for that. lets do it chuck norris style. 6 contestants and a fully loaded gun
HA HA HA you cock loving s**t!!! oh BTW he didn't call you a girl.....
i knew you gaging for it mike!! ;)
wait :happy:
I've always known :happy:
read post above.
:happy:
thats no excuse, your just losing your touch, admitting you have a problem is the first step in coming out of the closet john, theres no shame in it.
unless you walk outside, then you have much shame, and must wear bag to cover your shame :happy:
Ah little grass hopper you learn well.....
some day you will be come huge......... EMO
:happy:
wait :happy:
yeah but you dont complain, plus i make a lot of money from it ;)
:) i dont think you going to your lubed up guys is worthy as pwnage...
haha true
oil guys = ppl who suck out that oil in the ground to make your car run idiot.
if thats what you want to call them john :happy:
your secret is safe with me :happy:
were you over there giving them pointers on how to "suck"
HA HA HA
yeh i agree....
these 2 have been goin on about ghey shit for days now
they dont stop.... i think they're both got problems!
sounds like someones not getting anything at home :happy:
my problem is your still here!
:happy:
Guest
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
