see i dont need no flood control to be able to whore...a true whore has flood control enable :(
Yeh guys, a true whore has no flood control anyway. Shane's a super special whore. He can take about 7 c0cks at any given time. Now THAT's minimal flood control at it's best!
funny how that happends....
lol i know.
hey Matt how much did the is200 cost you? how long ago? i have a mate wantinh to sell his CRX and upgrae to one of them? did you get a sunroof and Leather trim?
The is200 cost me 18k 3 months ago. It is the sports luxury model so it has both a sunroof and leather trim. The cars are a bargain imho. My car was the cheapest in the country at the time i bought it. (from carsales and carpoint, altezza forums etc).
holly shit
IMKAOS r32 gtst skyline has been stolen.
http://www.cruisingbrisbane.com/forum/inde...c=28670&hl=
they got it back though the infor was a bit sketchy....
:( :( HA HA HA good work Sweetie...
Okay I need to do an hour of solid work, so i'll probably say hi again around 3.
Ciao!
see you then....
18K?? :( soo cheap!!
altezz forum? whats the site address will look into it more!
yea, you just have to keep an eye out for someone desperate and then take advantage of them. He had 23k on it..dropped the price to 20k and he took my offer after some "negotiation" and me telling him how screwed the car was (although it isnt). www.altezzaclub.org is the site although people dont frequent it as much as heree and theres a lot of NZ people on there.
but that would mean i'd have to put ur half in the bank
you'd earn the interest on it while ur locked away
thats no fair
man sif they jail me for stealing that car.... get the cash but the can't prove it was me ( :( cos it wasn't) then dont give it back he he he
That is one hot peice of gear...he is gay but cause he parked me in at Autosalon :(
:( and passionfruit yoplait tastes like bile
No yogurt can be bad yogurt
Guest
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
