bahaha it doesnt have any headwork, so ull be fine...plus have u ever heard any dramas b4?
ha ha I dont actually care, I was just stirring
But truth be told the story re that other engine s enough to put me off big time
Well Im sorry to say but I just bought that one off here for sale, I dont really need it and all I wanted was the head for a 25/30 that Im dreamin of but if you run into trouble I may be able to work somthin out with you
Ok mate! That would be really good! IF there is any problems Shane or myself will be in contact for sure
Just incase you missed this one on sat nite
Three obvioulsy pregnant women are in their doctor's waiting room....one is a red-head, one a brunette, and one a blonde.
The red head says that she' having a boy since she was on top when they conceived.
The brunette says she's having a boy since she was on bottom when they conceived.
The blonde starts crying and crying.....
I'm having puppies she wailed!!
lol crazy blondes
BUNTA....
wat u think of an electronic version of the SAU calendar?
meaning, the calendar itself will be your windows desktop background showing the car of the month with the calendar dates that will also be on the wall calendar?
Yeah I saw that...seems like a pretty cool idea to me
just did one for myself using my car and f**k it looks awesome!!!!
workin through each of the cars now picking out the photo's i've taken to which would best suit the calendar itself.
then got to enter in all the specs ppl have given me for their cars into the 'detailed' section on the calendar
sweet sounds like it is coming along nicely
had to get the ball rolling at some stage
hehehe
only got my car and noy's car left to shoot.
which reminds me i should organise a time with him this wk to do his car
got to wash mine first before i even go anywhere near it with a camera
didnt think actually doing the full development of the calendar would be much to it. found a few things on the net i've downloaded which has made things easier to do though.
Good old intawaeb FTW
Guest
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
