R32 Pix Only
Cheers for the tips, I'll go with 50 mm around the side, I'm used to digging with hand tools, my prior occupation had me going well with hand tools and there's nothing that a breaker bar and a pair of gloves to protect my delicate hands can't fix, hopefully... As my time now is free, if it takes a week to excavate that's not a issue
That's a pretty big job card assuming you're not planning on any machinery. I hope your dirt/rock ratio is not like ours, hand digging up here is very hard work I use the Mitre 10 in Sloane St or Gehl's Nursery where I can rather than Bunnings, but for bulk material everything (Goulburn Sand and Soil, Rocky Hill Sand and Soil) and is owned by Divalls (as is about 80% of town) so no point shopping around. Let me know if you need to borrow a ute or box trailer. BTW we also went with 7mm blue metal around the house, mostly for fire but also termites. You really need compacted road base under it then no more than about 50mm of rocks because otherwise they shift too much under foot. We also put corten edging to stop it spreading outside its area over time.
I'm not certain about the fuel hat connectors (noting, I DID have to replace the hat in my Stagea with one of these pumps) However, you 100% do need to do a properly sized relay mod, the factory wiring is definitely too small for these pumps.
