Some more random photos today after I cleaned her up a bit.
Im thinking about dropping her a smidget more, maybe getting some spacers to fill her out a bit more.
What do you guys think.
mmm... maybe. I think it looks fine as is and doesnt really need to be any lower.
Also depends how much you like to scrape over speed bumps and driveways as well :/
Now ya just showing off :(
Nice headlight intake too. Would look cleaner without the Bodyform vinyls though, unless you're sponsored.
THIS;
is a nice headlight intake :)
Link $270 delivered from japan (GTR size only)
Yeah I know about that and its ace but was just being appreciative of something thats custom made up (im assuming). Looks clean and very neat, so good effort.
I was actually even considering getting one of those for myself, but then remembered ive got N1 headlights, so it'd look weird :(
Edited by Yawn
THIS;
One of those would be perfect, but almost certainly a defect notice waiting to happen?
(I'd love to be wrong on that though...)
your probs right, they'll defect anything they want really haha
although technically i cant see why they should, it would still be a fully functional headlight with no sharp edges or protrusions,
but hey, if it aint stock they dont wanna know about it lol
