  • Replies 67
I had just about beaten the 9.349 & now you tell me we can use TCS :)
That's bloody good, feel free to post up a non TCS time, it started as pretty much "whatever you need to do" challenge so any mods are fine. If you could get the launch perfect then TCS off would be faster I'd say but that is going to be pretty hard...
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2230842
Ok. FULLY modded inc NOS but with the TCS & ACS turned off = 0'09.371. I'll post a screen shot when I can find my camera. Might try it with the TCS on & see what I get :P
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234644
9.337 is just about as fast as i can get it
With that sort of time I'd say your tuning is spot in, I had to break away from convention (well maybe it's not convention) in tuning my gearbox to get any faster. Hint hint, 5 gear changes in 9 seconds might not be the fastest way down the 1/4...
I had a freak run too...
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234839
so are you just holding the nos and accelerating flat stick the whole time?
thats how ive been doing it
so how many gears are you using over the 400m?
also are you guys using any ballast weight?
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234883
The Launch is the trick, need to get that right, then flat stick with Nos all the way, auto box but holding some gears a little longer using the gear shift button, 5 gears, using a taller final drive to get that, I was maxed out in 5th over the line.
Luke
Edited by munchdesign
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234900
Luke
hmmm,
i was playing gt4 for about 4-5 hours last night, takes ages to get all the specs sorted.
i'll muck around with some of the specs and see how i go
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2234944
Never really found drag racing on GT4 that exciting.
I love taking the wagon around the dirt tracks. But my favourite is the Nurbergring. You have to set your car up spot on to get a decent time on that track.
If the car is too low, and suspension to hard, it is impossible to control over the bumps. If it is too soft, it just wallows and handles corners like a boat.
From memory, I managed a sub 10min lap in a standard RS4. I don't have a lot of time to play these days.
The PS3 is out in November (at this stage) and will cost NZ$1000.
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2236258
  • 4 weeks later...
  • 1 month later...
sussing some rim options... oh and has anyone got PB's for nurburgring yet, listen to munch qualifying tyres are the sh*t, GT4 has consumed so much of my life i have 384 cars at the moment that includes about every model nissan out the plus 24 different GTR's, 8 different stag's.... i like different colours and rims :thumbsup:
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2405300
All Silver ones, can' be bothered taking pics of the other colours just yet, been playing heaps of 'Tourist Trophy' from GT makers only motorbikes if no one has heard, pretty good not enough game play tho, and pretty easy. Tips for anyone taking pics on GT4 turn the brightness up heaps in the game makes them a bit better.
https://www.sau.com.au/forums/topic/119868-gt4/page/3/#findComment-2432574
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
