I have a NEO RB25DET S14 Silvia conversion. Mods are - LinkPlus ECU, large turbo and all related boltons except injectors. I took the car to get tuned recently, but got a disappointing call from the tuner saying the motor wouldn’t rev past 4500rpm and he cant diagnose the problem. He loaded an R33 base map on the LinkPlus and I drove it home. The car starts and idles beautifully. Under 4500rpm it drives as smooth as a stock motor. Anywhere past 10psi however results in the aforementioned misfire/revlimit.
On the way home from the dyno, the car surprisingly revved to redline with no problems, which made me wonder what the tuner was going on about. The next day, I got in the car for another test drive, and sure enough it wouldn’t rev out past 4500rpm - just like the tuner said. It now occasionally revs to redline on 1st gear but never on any higher gears. The tuner suggested to try gapping the sparkplugs down to. 08mm. I tried this today but the car now doesn’t even idle with the gapped plugs. I removed the plugs, spaced the gaps back to normal and it fixed the problem. I find this very surprising, as ive never heard of gapped plugs disrupting idle?
I took the car for a drive and grabbed my camera. Below is a video that shows the misfire. Hopefully someone might recognise the problem? Notice how 1st gear rev limits and backfires at around 6000rpm. 2nd gear the motor simply doesn’t rev and sounds very weird, almost as if the wastegate is venting on and off? 3rd gear the same thing happens so I quickly change gear. The last clip I added to show how 1st gear occasionally decides to rev out nicely.
http://s2.photobucket.com/albums/y27/DRFT1...nt=MissFire.flv
Id love some help on this. The project has really stalled at this stage.
https://www.sau.com.au/forums/topic/119921-engine-doesnt-idle-after-08mm-gap/
I once had an issue on the dyno. We were doing 4th gear pulls and my speed cut was kicking in at 112MPH (179KMH). Therefore it enabled a fuel cut way before redline.
I'm don't think that this is your problem since you said it doesn't happen in 1st at times but it's a thought.
Are you running the correct heat range spark plugs?
looks alot like coilpack issues to me, though that wouldn't explain any issues with 0.8 gapped plugs
notice alot more black smoke out the back of the car when it is missing? i see more when mine does it, unburnt fuel.
Hey Buddy,
Is that Link plus ECU a piggy backtype?
If so, then, I remember someone saying that fuel cut on an NEO engine is around 9-10psi. You might not be hitting more than 10psi in first gear. Try winding the boost back. - Just a thought.
I should have said that im running wasted spark, so its not a coilpack issue. I tried new leads and brand new NGK Platinum spark plugs but that wasnt the problem.
The LinkPlus is a complete engine management system, not a piggy back so I wouldnt suspect a fuel/speed cut.
The boost issue is an interesting one, as it only seems to be cutting out after 10psi. The ECU is setup with a basemap for an R33, could this be the issue? Maybe the increased air flow from the large turbo at 15psi throws the tune way off? But in saying that, I doubt that would result with the engine being unable to rev like it does?
Are you guys able to view that video? Any thoughts on it?
Speeking of unburnt fuel, I noticed black drops of liquid sputtering from the muffler while it was idling yesterday. I tried smelling it but couldnt identify what it was. This especially happened after a changed the gap to how it was before the .08mm gap which didnt work. Could this be unburnt fuel? I find it pretty unlikely that fuel in its liquid form managed to travel all the way from the injectors and out my exhaust pipe though?! :)
Does that hint at anything? (The motor wasnt missfiring while idling)
what boost controller are you running? Sounds like boost cut. the reason it doesnt do it in first gear is because it doesnt see as much load, therefore less boost. Ive heard factory boost soleniod on Neo engine limit boost in lower gears. May be worth bypassing factory solenoid and running an afternarket ebc. Never seen ignition brake up at 10psi and doubt plug gap would be an issue at that boost either. Whos tuning it?
Edited by BezerkR32
Thanks for clearing that up GTST. A mate of mine told me it was 0.08. Even though I was pretty sure it was 0.80, I took his word for it.
Anyway, now gapped it to 0.8 and it idles fine. Misfireing issue is still not sorted though. Il ask again if anyone has any ideas after the viewing the video. If not, il take it to another tuner and have another go (even though I run the risk of getting hit with 75% of the tuning bill and come home with an un-tuned car like the 1st time). I took it back to my electirician, he went over it thrice and is certain there is no issue with the wiring or anything related to that. I tend to agree with him, if the car idles fine and runs great below high boost, surely it cant be an electrical fault? Im about to tear my hair out with this one!
I hope this is not your problem but I had a car that did this same thing, turned out to be a hairline crack in a inlet valve housing to water jacket, it only did it when the motor was working, ie if I stopped for awhile it would be ok untill engine reached a certain level (temp didnt move much) it eventually opened enough to fill a cylinder, that shot into the air when I cranked it over lol (no plug motor wouldnt turn over).
One of our customers with a R33GTST had a mis-firing problem; he had the stock coil packs and 0.8mm iridium spark plugs.
We fixed the problem up by gapping these to 0.75mm - all solved.
I think he was experiencing constant mis-firing at anything above 4,000RPM.
Hope this is a little bit of help
I don't know alot about this sorta thing, hell I don't know alot about anything really but I do know that 0.08mm is a Gnat's dick of a gap. Perhaps when you gapped them that small you damaged the electrode and thus when you gapped them back to 0.8mm they won't work properly?
Just a thought.
Are you sure it's a misfire? Many people just use this term for lack of a better descriptive word. Won't rev over 4500 grand would indicate that it won't, or has trouble, revving over 4500 grand, not misfire. Check basics first like fuel pump (pressure and flow). So many of you are concerned with a spark issue but it takes more than spark to make a car run.
CHECK BASICS!
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
