Just wondering because I have an issue with my cefiro (same wiring as r32 for the most part).
I've plugged up the reverse sensor from the gearbox (2 wires, green and green with black trace) to the loom at the relay box on the drivers front side of the engine bay. I've just matched the colours as that's how it is on too_much_boost's cefiro.
Problem is I still don't get the reverse sensor going on or my reverse lights going on. I know it's meant to go into part of the loom near the relay box as that is what it used to do before I re-wired it and lost which place it was wired into (duhh).
The reverse sensor works as those 2 wires send current/do stuff when I put it into reverse.
Question is does anyone know the path of the reverse sensor wires? i.e. where do they go after the loom near the relay box? I'd like to trace them further.
Any help appreciated - reversing at night is driving me nuts.
https://www.sau.com.au/forums/topic/119982-reverse-sensor-in-r32s/
