R33GT-R:
Side window D/S: $250
RB26DETT:
Lambdasond: $100 - SOLD
Con rods: $250 (7)
Oil cooler: $500 - SOLD
Fuelrail: $70 - SOLD
Gasket oilpump: $15
Blackpainted manifolds (probably cheramic coated): $100
Crank angle sensor: $40
Engine mounts: $60
Throttle linkage: $60
Clutch: $250 - SOLD
Throttle bodies: $200 (incl 3 gaskets) - SOLD
Head gasket: $100
Twin Turbo pipe: $100
Boost solenoid: $60
Coil packs: $180 - SOLD
Blow off pipe: $25
Other:
Nismo shoulder pads: $25 - SOLD
Pictures and some other parts can be found at the link below:
http://www.jolie.nu/skyline/delar/
(Australian dollars)
Edited by ThomasL
https://www.sau.com.au/forums/topic/120183-lots-of-parts/
will that oil cooler fit a 32 GTR?
Definitely since there's the same engine. You just have to find a suitable place for it. The hoses are long enough for mounting it in front of the blow off valves om my R33GT-R, so it should fit nice on your R32.
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2214233
ugot stock turbos? was after 1
Yes I have one in excellent condition. But the strange thing is that I have misplaced it somewhere. Have moved recently and have had the car at the mechanics, but it surely is somewhere. Will of course have to find it first. :mellow:
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2218003
Yes I have one in excellent condition. But the strange thing is that I have misplaced it somewhere. Have moved recently and have had the car at the mechanics, but it surely is somewhere. Will of course have to find it first. :)
well hope u find it!! wat would u be looking for it once u've found it?
https://www.sau.com.au/forums/topic/120183-lots-of-parts/#findComment-2221077
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
