I have some on my work computer but am not in till tomorrow afternoon.
Until then its: http://www.horsepowerinabox.com/HPIAB2/prod18.htm
Any questions welcome. Looking for quick sale at this price, can post asap.
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2216317
Comes with actuator, but no water or oil lines.
Have someone checking it out tomorrow, so if your interested let me know. Its at G&D performance in Cranbourne if you want to check it out.
As I understand its built for a standard RB25 manifold. Read the horsepowerinabox link for exact details. It fits the T3 flange.
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2216385
what power were you making @ what boost? And when did yu see full boost?
cheers
Well i had it on a commodore (please dont hurt me :D ) so i saw full boost just off idle! Being a 3.8l engine it was just a little too small of a housing. This turbo is designed for you guys so I wouldnt be worrying about power figures. It will give you more than you can handle. Basically, on 14-17psi it should make around 280rwkw on your engines.
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2216402
"Should" and "Does" are two totally different things, unless you are offering a money back guarantee. On a std engine, you would need more than 17psi to make 280rwkw.
Don't mean to discredit your sale, as it has been proven to be a good turbo, just don't like reading figures that have been pulled out of the air.
Good luck
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2216722
Yeah of course dude. People are asking me for dyno sheets. I am saying that a dyno sheet on a 3.8L engine is pretty much meaningless.
I got that power figure from this site. All I am saying is it is this turbo and some indication of the potential. It is made for a 2.5L skyline not a commodore.
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2216846
i had one on my rb25 it pulled 277 rwkws on 98 ron fuel at 21psi. 283rwkws on 100 ron. great turbo! starts to spool at 2500rpm on a stock rb25 and full boost by 3500rpm. comes on really hard !!! if you guys want to see dyno sheet pm with your email address and i will send you one. cheers carl.
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2217981
The turbo has only been running for a month or so in an very restricted setup so as to pass an emissions test. Then it was back to build.
Car has been off the road for the rest of the time since purchasing last year.
Edited by Harey
https://www.sau.com.au/forums/topic/120300-sold/#findComment-2218502
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
