I've got a bee in my bonnet over a common belief (from some very well respected members included) that coating/wrapping/insulating the exhaust manifold to keep the heat in makes a marked difference to turbo efficiency.
Sorry guys, I just cant subscribe to this theory. Sure, the basic gas law principles apply (i.e. the hotter the gas the higher the pressure and therefore the faster the exhaust turbine spins), but really, what is the temperature difference going to be between an insulated and uninsulated manifold.
There is a huge gas flow (even more than on the inlet side) and the surface area is relatively small. I would therefore sugest that for a given volume of gas, the temperature drop of the exhaust gas is relatively small as a fraction of the total temperature.
Lets consider a drop of 5C in the exhaust temp. This relates to a percentage drop in temperature of 0.5% assuming an exhaust temperature of 1000 Kelvin (remembering we need to work in absolute temperatures). As there is a direct relationship between temperature and pressure, this equates to a similar drop of 0.5% in pressure applied to the exhaust turbine.
OK - perhaps some may argue that there is a larger difference in temperature between insulated and uninsulated manifolds? I personally just can see it as really even a tubular, thin walled manifold is a pretty inefficient heat exchanger in size and design.
However, I certainly agree that the exhaust components in and near the engine bay should be insulated to stop the engine bay temperatures from rising. I also spent a lot of money on ceramic coating turbo exhaust housings, manifolds, dumps, from pipes etc. I did this from the point of view of lower inlet temperatures and avoiding heat damage to hoses, abs, wiring etc near this area.
In conclusion - I am far from convinced that there is enough heat loss to markedly affect turbo efficiency. If someone can show me otherwise - I have an open mind, however :D
  • Replies 50
Posted Images
I wrap the primary pipes to keep the heat out of the engine bay. Any heat kept in is a bonus.
:D cheers :D
It is dyno proven that the more heat you can keep inside the manifold, the more efficient the results will be. You will not only spool faster but reach full boost quicker as the pressure difference is somewhere around 30% not 0.5%.
That is why most people complain about power loss after swapping their cast manifold for a custom stainless one, because cast holds the heat in for longer whereas the stainless will dissipate it more quickly.
As you already know, it is heat that drives the turbine....so the more you can get into the housing...the better.
The more heat in the gas and the less in the surrounding components etc the better.
Hotter gas through insulation would theoretically help spool up as well. Same goes with wrapping the dump pipe for faster exhaust velocity.
We agree with the concept - the amount of loss is where we differ. You claim 30% pressure difference due to heat loss? This means that 30% the exhaust gas must be 30% cooler due to the tubular manifold (i.e. from 1000k to 700k - or from 727C to 427C) - it just can't be so - sorry.
Edited by Gav
It's not due to tubular manifold....I was using that as a seperate example.
The heat wrapping or coating will hold 30% more heat than an unwrapped/coated system
Heh, so if Gav is correct we might as well take the ceramic tiles off the space shuttle and see how it goes through reentry :)
Nah - Space Shuttle is "Old Skool" and uses plain old Chemical Accelerant (liquid oxygen) - no turbos on those Bad Boys :)
:mellow: cheers :mellow:
Hey,
Does wrapping have a downside (accelerated primary pipe wear,
"too hot" for the primary pipes/turbo, other?)
Regards,
Saliya
In theory we see a gain, in practice it would very much depend on the materials used to the degree of gain. At the very least we're reducing the heat transfer into the engine bay by keeping it in the pipe and we're reducing the heat transfer from the gas to the metal pipe itself...
I've ordered a 6boost low mount turbo manifold for the GTST which is HPC coated for my 2835ProS. I will post before and after dyno sheets when this is fitted [ may be a few weeks ].
While I dont expect huge gains in rwkw I would expect small gains and slightly better curve.
Keeping an open mind. We'll soon see.
It's interesting that the material of choice for aftermarket manifolds seems to be stainless steel. This expands/contracts much more than plain old mild steel and tends to crack at the welds more often. Cosmetically there is bugger all difference if you are going to coat/wrap them anyway as well!
Hey,
Keep in mind, unless you dyno the _same manifold_ before/after coating, these dyno sheets won't
shed any light on what's being questioned in this thread. If you receive your manifold already coated,
the results are from manifold + coating change, not just the coating. And from all accounts the 6boost
manifolds flow excellently.
I've _just_ received my 6boost manifold (workmanship is nice; the timeframe estimate was way off :D)
and I'm still tossing up whether to coat it or not. I'd really prefer the coating to be on inside and out if I
was going to get it done... but nobody seems to want to guarantee the coating against flaking off and
destroying my turbine.
Can I be a%&ed fitting it up, dynoing it, then pulling the entire manifold off _again_, sending it
away for coating, refitting, dynoing again, retuning (if needed) and dynoing for a third time? Probably not.
If the coating is worth all that much in terms of HP gain you'd expect that one of the coating vendors
would have done a controlled test to document the gains their product provides. A quick look around
doesn't exactly provide lots of graph evidence one way or another regarding exhaust manifold coating.
Those dyno results I did find related to ceramic coating engine internals, not manifolds.
Most of the vendors say something like "there is a noticeable drop in under-bonnet temperature"
before/after. You should be able to rely on this. As for a noticeable HP change - still looking for graphs ;)
Regards,
Saliya
Can I be a%&ed fitting it up, dynoing it, then pulling the entire manifold off _again_, sending it away for coating, refitting, dynoing again, retuning (if needed) and dynoing for a third time? Probably not.
Exactly why it isn’t done, very time consuming and difficult to duplicate the exact conditions. Also difficult to isolate the under bonnet temperature reduction (horsepower improvement) from the increase exhaust gas velocity (horsepower improvement).
What I can say is I have wrapped the primary pipes and collector on an N/A V8 and it picked up 18 bhp, that was on the engine dyno. The principle is basically the same, maintaining the exhaust velocity to give better scavenging.
:D cheers ;)
Hey,
Regards,
Saliya
There is another way. You can take an infra red photgraph of the exhaust manifold section that has been coated. If (& only if) the coating works you will see a significantly lower temperature on the exhaust manifold section that is coated. If it doesn't work you won;t see any real difference between the coated & uncoated sections. Do a search - you should find it.
You can actually measure it with an infra red pyrometer.
We do that to check individual cylinder tune.
:D Cheers ;)
Took this snippet from the HPC site
Benefits of using HiPerCoat Extreme™
On-tracking testing has shown as much as a 35% reduction in under hood ambient temperature and more than 50% reduction in component skin temperature. HiPerCoat Extreme's™ superior insulation qualities mean increased horsepower for your race or turbo-charged engine. HPC’s HiPerCoat Extreme™ helps to maintain exhaust gas temperatures, increasing flow velocity, aiding in cylinder scavenging and decreasing turbo spool-up time.
An additional benefit is the reduction of underhood temperatures, preventing damage to hoses, belts and wiring harnesses. Independent testing of a turbo charged Mazda engine has shown a 5% increase in horsepower when HiPerCoat Extreme™ was used on the exhaust manifold, turbo and downpipe.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
