Hi all,
Planning to put some Type B Poncams in very shortly and just going through the instructions that are in Japanese. There is this whole section on a modification that you have to do to the BOV - unfortunately in this case, pictures don't tell a thousand words and I'm quite confused.
Has anyone done this or has any idea what is required?
Any help would be great,
Thanks
Stan
Yes it's to do with stock blow-off valve! :D And it did show instructions to block up "some" hole, not sure which one though.
On the diagram it's very tiny.
I'll try get the pic up sometime soon.
Oh yeah the stock BOV trick. Basically you pull it apart into halves and you'll see a small hole to the left of the piston. Jam a screw or something else to plug it up and then reassemble. Stops it from 'leaking' apparently.
Cheers to everyone who has helped, you've been fantastic, especially to the guys with photos :laugh:
Now, what if I don't have a BOV anymore (completely removed, blanking plate used instead). Does it mean that I don't have to worry about this?
  • 3 years later...
Old thread revival but..
Satanic - do you have the instructions still from Tomei showing this mod.
I have done it and the car feels a lot more responsive. However It doesn't seem the BOV is functioning as it's intended after this mod according to what Ive read
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
