  • Replies 73
Posted Images
Is that in reponse to my #1?
If that is the case, then I am not sure that we are talking about the same thing.
With the longer rod, the piston is around TDC longer for the same number of crankshaft rotation degrees. Hence “around longer” means while the combustion is actually occurring, That’s why I say “Thereby giving an increase in combustion pressure, this means more torque per firing”.
The angle of the rod at ½ stroke is something altogether different. Where the longer rod is also an advantage as the right angle to the crank occurs earlier in the combustion process. Therefore imparting more torque at that time.
Or have I missed something?
:( cheers ;)
With a lower rod ratio, the rod will be normal to the crank earlier in the combustion cycle, not later (ie. closer to TDC, meaning more force transfered to the crank pin and more torque.
But I agree with you, if you want an engine to last, especially at higher rpm, longer rods are better.
This page explains it well: http://e30m3performance.com/tech_articles/...namics/dyn2.htm
Hey guys, once again thanks for the interest, when i started this thread i thought the interest would centre aronud the gt-rs turbos, as these are always the centre of debate...
Again though please dont think im trying to say what i've done is ultimately better than using a brand new jap brand stroker crank, most of those cranks are a real nice bit of gear. However, value for money i may be able to compete on. For me it was just time as i have all the equipment at my disposal, but im in the midst of trying to figure if i can do this conversion at a cost that is both economical to me and to customers. To do this ill have to be well under the price of those kits. Im thinking that this conversion is good for people who've just trashed a crank through oil surge, and are looking at building a new bottom end, and need another crank anyway. One other thing to think on is while my crank is not fully counterweighted, this may be a good thing for a drag application, as fully counterweighted cranks are quite heavy. Lightweight cranks are always limited life but for drag work often this is not a worry
We have GT-RS turbo's and will change back to 2530's if i can't overcome the lagginess (is that a word) of them. Larger capacity seems the only answer.....or a shot of gas off the line to spool them up quicker. mark99 our car is drag only so may be a candidate for your crank upgrade.
Disclaimer: The above post could be and possibly is total bullsh1t
While on this GT2530/GT-RS(2871R-52T) has anyone thought of using HKS's GT2535 turbo's ? From their specs they use the same turbine as 2530's and GT-RS's but the compressor is an unusual 69mm diametre so may prove a little less laggy than the GT-RS's 71mm compressor depending on wheel trim and housing AR . I have to assume its compressor is a special by Garrett for HKS which they do at times . I'm not sure if its available with housings to suit an RB26 but its food for thought .
Cheers A .
Paul...when you say 'lag', do you mean throttle response (as in how long boost take to build when you open the throttle at enough revs for boost) or boost threshold (as in how many RPM are needed to build boost)
I always found the GTRS to be excellent as far as 'lag' goes.
What does your boost curve look like now? With the same cams as you have and a stock engine, I had 1.3 bar at about 4800-4900 RPM. That's not too bad, it's only a couple of hundred RPM worse than 2530s or 2860Rs. That was without any funky cam timing too...was running 110/113 (or whatever PONCAMS run...forget now) lobe centres.
Grab a laptop and head out to the track and play with the spoolup. You should even be able to do it on the freeway as you don't need to be doing ridiculous speeds to tune the spoolup area.
boost threshold...there is now a 1000rpm hole in my torque curve...ie. similar power and torque as before but 1000rpm later...but in saying that, we made more power but later on in the rev range and still climbing at 9500rpm. I don't want to rev the guts out of it to make the similar numbers as before and the off the line torque of the 2530's is now gone. Dropping it at 8500rpm-9000rpm off the line is bogging the car on launch...instead of 1.4 60' times with instant throttle response and the tyres on the limit of grip.
hey dirt garage any chance of seeing that dyno sheet? also i remember hearing somewere that a rb26/30 at 7000rpm or was it 7500rpm will make the same power as a rb26 will at 9500rpm?
so yer power still climbing at 9500rpm.. maybe more cubes is gunna have to be the option?
  • 1 month later...
  • 3 weeks later...
Sorry in the delay with updates, been absolutely flat out....
I put bigger injectors in and the car ended up making 406rwkw @ 18 pounds on pump fuel. Any more boost and it only picked up small amounts of kw and started to heat the air, not sure if the turbos are maxed out or if something in the induction setup is causing a restriction... not sure if my cooler is big enough. I've got another dyno sheet but its done in shoot 8 insted of shoot 6 so the torque figure is different due to the different ramp rate?? ( i dont know much about dynos). The power curve looks identical, just goes a few kw higher... To drive, the car is nice and broad and controllable in power delivery,pulls well from 3000 rpm and hard from 4500 through to 8500rpm...
Ive two more cranks almost ready to go, and more started for those that are interested. Please PM if you are intersested, so we can discuss options. It can be set up with std rods, or after market, 21mm or 22mm pins. My car will be on display at Adelaide auto salon, as will a 2.9l short engine. As usual any questions, comments or ideas just shoot
Mark
Ahh nice work mark,
what price would someone be looking at for an engine built. would you be able to break down the costs also.
Looking good otherwise! i'd see this as a nice setup for the new large singles that have been comming out recently.
and for those of us that cant fit a 3litre underneath due to not wanting to get rid of the stock bonnet :dry:
Im from Rhemac Motors, we are a performance engine machining shop. Prices for a built engine really would vary, depending on brands of parts used, std rods or aftermarket, how big a cams etc etc. PM me a phone number and i can call you. But ball park, crank and custom CP pistons, pins and rings $4000. By the time you did a whole engine and assembled it, start around $9000 - $10000 depending on what options, and then go from there with yet more options. Ill try take some pics on the weekend and post em up
Guest Mashrock
Thats ok mark, i'm not actually looking at getting this done as i am happy with my setup and i dont have money for engines at the moment. possibly more a future thing.
i understand that there is alot of variation in engine building and final cost would vary alot.
still glad to see this, and hope all goes well.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
